matth555 10 Posted August 4, 2017 Hi, I wondered if anybody had the connector for the wiring loom that the lambda sensor plugs into for a 2.0 16v or G60 ( I believe they should be the same). I Bought a genuine Bosch sensor to try and sort my running issues out only to find some clown has chopped the connector off and spliced a cheapo sensor into the loom (badly). Ideally want the connector with a bit of the loom so I can solder it back in. Thanks in advance. Matt Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 5, 2017 I did have that exact connector chopped off a spare mega low mileage 2.0 9A 16v loom. I'll have to look for it amongst a huge pile of bits.. Later on I've got to get some photos of bits for other members so if it's there, I'll snap a few photos. Quote Share this post Link to post Share on other sites
matth555 10 Posted August 5, 2017 Brilliant - let me know how much you want for it if you can find it. Many thanks. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 5, 2017 (edited) Ok, I found one, not the valver one but as long as it's an original plug, who cares.. god knows what happened to the 16v one I had. I'll include 5 new junior timer terminals so you can reuse your existing wiring cut back an inch or two to remove the cooked bits of wiring and install the new terminals. This one I have is just as bad wiring wise as yours mate.. Normally, there's sufficient slack to recuperate the wires. All you'd need is a cheap crimping tool. Send me your email and I'll get you a couple of photos sent. Cheers. Edited August 5, 2017 by VEEDUBBED Quote Share this post Link to post Share on other sites
