VEEDUBBED 0 Posted September 13, 2017 Have you tried disconecting the high pressure pipe and putting it in a transparent container with the engine running? any fluid pumped out? Does the level fall in the oil bottle? You could also try this, get a cut down bolt that's head fits inside the power steering pump's hex cut out on the pulley shaft, remove the serp. belt and spin the pump over using an electric drill this may dislodge any air present that may be trapped. I reckon you could briefly spin it even anti-clockwise, just put the drill on low speed to avoid buggering any one way valves present. At this stage, it's worth a punt. Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 13, 2017 Christ , this is a right ball ache . Hope you get it sorted chaps . Quote Share this post Link to post Share on other sites
