Stone0311
G60 Engine Bay Remob - Electrical Loose Ends
Going through my wiring harnesses prior to install with a bit of a tuck, can anyone shed any light on the loose ends below?:
> Yellow connector on LH Front wiring harness - would be around the headlight location; returns to a separate plug from the fusebox?
> 3 Wire connector on the LH front wiring harness - would be around the exp tank area? (Ignore the previous butchery, not mine)
Can find either in the wiring diagrams, so any help appreciated.
I cant see your pic but the yellow plug is unused on mine but i do have an uprated headlight loom. The instructions say to unplug it but it was never there on mine.
It used to go what i believe to be called a ballast resister some thing to do with headlights.
3 pin plug what wire colours and ill have a look at mine tomorrow for you?
Hi STU175, I remember there being a ballast on the old 16v loom - mine was on the drivers side tho.
3pin plug colours in order - Brown, Green/Blk, Blk/White
Thanks
For clarity the second pic is the fusebox end of the cable in the first - not that it sheds a lot of light
The one with the 3pins is in the same location as the exp tank sensor plug
