a_riot 0 Posted November 20, 2018 Just mentioning this in case others encounter it. I was having issues with my reverse lights for a long time, and finally got around to fixing it. They were intermittent for a while, depending on where the gear lever was, then would only briefly flash on when put in reverse. I removed the connector to the switch and shorted the terminals and the lights came on fine. So I removed the switch to see about replacing it, but once removed, I noticed the pin inside it the sleeve must hit, was kind of dirty and not moving smoothly. It only moves a couple of millimeters but I guess there was enough gunk in there that it wasn't getting a reliable connection. I shot brakekleen in there and lubed up the chrome lever, reinstalled and its now working fine. I love old cars you can actually fix! Quote Share this post Link to post Share on other sites
fendervg 33 Posted November 21, 2018 Good tip - is the switch on the gear lever housing? On some cars it's in the gearbox itself. Quote Share this post Link to post Share on other sites
a_riot 0 Posted November 21, 2018 fendervg said: Good tip - is the switch on the gear lever housing? On some cars it's in the gearbox itself. It sits on top of the transmission lever assembly, so fairly accessible in the engine bay. Its right under the lower radiator hose, but still fairly easy to remove with two screws. Its a cheap part, but now that its fixed it will probably work for the next 25 years :) Quote Share this post Link to post Share on other sites
