_Matt_ 28 Posted February 1, 2019 Hi, I found this great thread but the pictures have gone http://the-corrado.net/showthread.php?16534-Trolley-jack-points I want to be sure I’m jacking and supporting in the right place. So far I have only needed to jack up front. I jack up at the rear of the subframe (or is it wishbone) mounting point to the chassis. I then place my axle stand with a hockey putt on the sill jack point. I keep the jack in situ sharing the strain. Is this okay? I haven’t done the rear but any tips would be appreciated. Cheers, Matt Quote Share this post Link to post Share on other sites
_Matt_ 28 Posted February 2, 2019 Done some digging and found the info and pics - sharing for others: Generally - always use wood or some rubber on top of jacks and axle stands - hockey putt or old suspension top mount. These are the jacking points. Best to not use a trolley jack on the seems. Either use the 2nd pic or some wood behind the seems in the green areas to jack: [ATTACH=CONFIG]95876[/ATTACH] When jacking the the front use the green bolt or around it if also using it to support on axle stands: [ATTACH=CONFIG]95879[/ATTACH] Alternatively you can use the rear of the front sub frame, but my jack does't easily reach that far. [ATTACH=CONFIG]95882[/ATTACH] 1 Quote Share this post Link to post Share on other sites
Dox 23 Posted February 2, 2019 I never jack or support a car on its shell, always a subframe or axle Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 3, 2019 (edited) I never jack or support a car on its shell, always a subframe or axle Me Too Edited February 3, 2019 by delfinis38 Quote Share this post Link to post Share on other sites
_Matt_ 28 Posted February 3, 2019 Yeah I usually do the middle picture. My jack is too short to reach the last picture, i need to buy a proper jack and keep my existing as a spare now I'm getting into working on the car. Although the body parts are the factory jacking points I feel uneasy doing it now the cars old. Quote Share this post Link to post Share on other sites
pbradley98 0 Posted February 9, 2019 Really helpful post - thanks! Quote Share this post Link to post Share on other sites
