Keyo 47 Posted March 16, 2019 (edited) Ive found the striped clip under the seat for the fuse clip trim so just need the part circled. Does anyone know the part number for this clip as it might be used for other uses in the VAG range and be available. Thanks in advance [ATTACH=CONFIG]96546[/ATTACH] Edited March 16, 2019 by Keyo Quote Share this post Link to post Share on other sites
vw rule 19 Posted March 16, 2019 Hello there, you can still purchase the clips but they come as a set per each side, I don't think you can get just one piece of one set if you know what I mean. The part number is 357857971 They are available on Ebay or possibly VW Heritage, or someone on this Forum might have the item you need. Hope this helps Si Quote Share this post Link to post Share on other sites
Keyo 47 Posted March 17, 2019 (edited) Hello there, you can still purchase the clips but they come as a set per each side, I don't think you can get just one piece of one set if you know what I mean. The part number is 357857971 They are available on Ebay or possibly VW Heritage, or someone on this Forum might have the item you need. Hope this helps Si Thanks for the reply I have seen them on ebay and they are an absolute rip off as Kip on here has mentioned there is a scene tax attached to these cars that inflates part costs . I was hoping that the housing clip I have circled is available stand alone as it might be used else where in the VAG range. I even saw a second hand battered light switch on ebay for £70, you can get them new for less then £30 some right chancers on the fleabay. I have managed to get the right angle philips head plastic clips for the tailgate trim as purchased a second hand tailgate trim for £20 with the clips and have a spare tailgate trim or could sell. The fuse clips did come on the Jetta and the transporter van to as stated on oempec. Im suprised someone with knowhow has not got a 3d printer together and made some parts because the postage and some of the prices from Germany are very exspensive. You ave to pay £7-£15 postage on top of the part which really makes it exspensive. Parts that could be printed and obselete. Fuse trim clips Seat tilt lever and trim surround A pillar caps B pillar and tailgate bungs Binnacle corner trim covers Front grill decal Tailgate trim philips head clips And so on its about time we got a list of hard to find/rip off top ten and approached a platics manufacture or DIY 3D printer in the UK. Somoeone like this may have the contacts. https://www.vehicleclips.co.uk/parts-by-make/volkswagen.html Cheers. Edited March 17, 2019 by Keyo Quote Share this post Link to post Share on other sites
