geordiedoors
1990 1.8 16v swirl pot.
I would try these three mate in descending order.
All on facebook
Chris Ferry or username on here lilfuzzer
Brendon Moss of Dubstock
Mathew Palmer Mk2 golf spares
Here is a couple of threads that might help about uprating fuel pump or alternatives to a swirl pot.
http://the-corrado.net/showthread.php?84555-16v-fuel-pump-complete-Wanted
https://www.clubgti.com/forums/index.php?threads/upgrading-fuel-pump.282505/
Im wondering the Golf Mk2 16v swirl pot works or even the 8V swirl pot but as mentioned the Corrado has a different part number but the bracket is the same on both models that houses it to the underside of the floorpan.
Edited by Keyo
Unfortunately chap it does help opening a FB account to source classic parts, mind you can just leave the profile blank or make up a name, no need to have your private details on facebook for the world to see.
Club gti has alot of stuff on there something about using a MK3 filter and Mk1 pump.
Thanks for the advice about Facebook, not found what I'm after yet, but options are much better ��
I know matthew palmer has one but one of the brackets is broken that holds either the accumulator or fuel filter. drop him a message but you would have to drill a hole and use a cable tie for the bad bracket.
You can always type in corrado breaking on facebook and see what comes up. Always pay via paypal for protection.
https://www.facebook.com/groups/768808459938759/
Edited by Keyo
Good stuff mate sounds promising. It is a really rare part because it was only ever made for a 16V KR Corrado. The Mk2 golf 16V is hard to get as well but more common, I keep a couple as spare just incase.
Edited by Keyo
