Cressa
Fusebox clips .... solution
Ok, so not the same shape  but a perfect fit. (Well it is on mine) the round trim clips that hold the vents on the trim at foot level.
See photo.
Part number 191 857 971 and available from Classic parts for just over a pound each
I hope it helps someone, as 40pounds on ebay for a couple of the fusebox clips is taking the pi##
Great find and thanks for sharing.
What is the part number for the round clip?  I think the part number 191 857 971 you quote is for square clip.
Thanks in advance.
So  confusing...   I have just rang heritage and confirmed the part number as above. But like you say, that shows so the square clips on google. I will wait and see. If totally wrong I will delete the thread.  I did explain that it is for the lower vent trims... watch this space 🤔
