Mawrick
Ideas about fitment for gearbox on a Passat B6 ?
Anyone in here have any ideas if a HDV gearbox is a direct replacement on a car that have a JLU gearbox ?.
this is on a 2.0 TDI 140HP, with a BKP engine (which at the moment have a defective JLU gearbox).
Any tips would be appreciated 🙂
Hello there,
looks like both gearboxes are 02Q which is 6 speed and have similar specs, in fact they appear to have the same gear ratio set up range between them.
1st gear 49 : 13 = 3.769
2nd gear 48 : 23 = 2.087
3rd gear 45 : 34 = 1.324
4th gear 42 : 43 = 0.977
5th gear 39 : 40 = 0.975
6th gear 35 : 43 = 0.814
Reverse gear 36 : 23 x 13 : 14 = 4.549
Final drive for (1st to 4th gear) 69 : 20 = 3.450
Final drive for (5th to 6th gear) 69 : 25 = 2.760
Code JLU  (2006 onwards)  = oil capacity 2.3 litres
Code HDV  (2004 onwards) = oil capacity 2.3 liters
PDF file of the workshop manual for the 02Q gearbox with code HDV, which has all torque settings. Attachment below.
Hope this helps
Si
6-speed_manual_gearbox_02Q.pdf
Thanx appreciated, that would help 🙂
Also got it more or less confirmed from a local VW garage that they came up as direct fitment for each other so think this should be good 🙂
Si
