FrankyEight 10 Posted November 9, 2021 (edited) Hi guys, My fuel gauge has recently died, it gave some bouncy readings for a while but has now completely gone — I'm looking for a replacement part which I think is the float-sender-thingy that sits in the tank — anyone know where I can get one? Part number I think is 191-919-051/G (3 pin) or 191-919-051/ba (4 pin) — any advice or help on this greatly appreciated. I've got an M reg 2.0 16v. Thanks. Edited November 9, 2021 by FrankyEight Quote Share this post Link to post Share on other sites
fendervg 33 Posted November 9, 2021 Did you try moving the float by hand with the ignition on to see what readings you were getting? I think if you short the wires you should get a full reading. The float senders rarely fail unless the fuel was contaminated or it was left empty for a long time and the tracks have worn or corroded. It could also be the dash voltage regulator on it's way out. The 191 means it's a Golf 2 part, so should be easier to find - if not new, could be had from a breakers or second hand Quote Share this post Link to post Share on other sites
FrankyEight 10 Posted December 6, 2021 Cheers for the reply. Pretty sure now the part number I need for the 4-pin fuel guage sender unit is '191 919 051 ba' — can't find any of these anywhere online... Anyone got one lying around?!... Quote Share this post Link to post Share on other sites
