.A.N.T.
The squeal deal...
Here's an annoying problem I wouldn't mind sorting soon....
I've recently put on FK coilovers and wound it down so it's nice and loooow.
I've also replaced the front wishbones as the rubbers had perished on the old ones.
Now when I'm cruising there is a squealing noise coming from the front passenger side wheel. If I accelerate hard it goes away, as does it if I let off the gas altogether or put it in neutral and coast.
Its a really nasty squealing noise like a fanbelt slipping, but i know it's not any belts on the engine as you can rev the engine all you like with no noise at all (other than the normal nice induction :twisted: )
Gunna try regreasing the wheel bearings tonight, but other than that I'm stumped.
There's nothing rubbing, and when you jack the car up and spin the wheel there's no noise.
Could the fact its low be causing this?? :?: :?: :?:
