bigbob
Speedo dials: fitting problem
i removed the bits of the dash that sit infront of the speedo dial as i was changing my bulbs in the dashboard
the bits are:
-the plastic box that holds the dials
-the clear plastic screen/box that sits in front of them
-the black slide in tray
i have put them all back in, but the last item, the tray, sits too far out from the dash and cannot be screwed in
its quite hard to explain i guess, but its never gone back together properly since i removed it all and i cant see why not
if you need a photo to clear the situation up i can post one
cheers in advance
chris
yeah post one it sounds like you screwed the box into the wrong holes, there are other holes that are closer to the front of the dash in my US corrado, the real ones hang out further back at an angle.
Its a bugger to get back in as its very tight... I spent alot of time fiddling with mine to line up all the holes properly and push it in....
It kind of pushes in then downwards slightly...
result: got it all back in today
there is 2 little plastic runners that need to slot in first before you put it all in
it now sits properly and it all fits smooth in the dash :)
