20v turbo 0 Posted August 18, 2004 which one have people on here got the 25mm or the28mm one. though i'de seen a thread on here about them but cant seem to find it. cheers 8) Quote Share this post Link to post Share on other sites
ben16v 0 Posted August 18, 2004 hey kevs your man to talk about arb`s do a search for: neuspeed ARB with author: kevhaywire just came up with 30-odd relevant matches 28mm if your brave sticks in my mind!!!!! Quote Share this post Link to post Share on other sites
20v turbo 0 Posted August 18, 2004 found them now m8 8) think i'll go with the 25mm one as i dont want to comprimise the everyday driving Quote Share this post Link to post Share on other sites
ben16v 0 Posted August 18, 2004 thats what i thought too! i`ve got a rear ARB on my wish list!! found them now m8 8) think i'll go with the 25mm one as i dont want to comprimise the everyday driving comprimise everyday driving....dont you get shed loads of wheelspin??? surely that will comprimise things?? LSD, 4WD .... i bet there all on your shopping list!! 8) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 18, 2004 I would advise you use just the rear one and 25mm and retain the stock front bar. I've got the 25mm front one too and you have to be so alert on bumpy country roads! The front bar trys to keep the wishbones *too* flat and as a consequence you can find yourself veering off in all sorts of directions, LOL! I can live with that as the cornering is absolutely unbelievable :lol: I'm going to dial in a bit more negative camber to restore a bit more front end stability. I'm currently running 0.75 negative, I'll knock that out to -1 or -1.2 and see if that improves matters. With just the rear bar, you don't get any of that but you do get phenomenal rear end grip and totally flat cornering. The only thing that gives is the tyre sidewalls. If you're a brave man, go for the 25mm front and 28mm rear cranked up to max stiffness :shock: Or you could go with the Eibachs, they're pretty darn good too but any uprated front bar will make the car a handful on bumpy roads. Quote Share this post Link to post Share on other sites
ben16v 0 Posted August 18, 2004 hey kevs your man to talk about arb`s see i told you so!!!! Quote Share this post Link to post Share on other sites
20v turbo 0 Posted August 18, 2004 just getting the rear to start with and thanks for the advise 8) benji16v, yep m8 all of the above are on my shopping list :D Quote Share this post Link to post Share on other sites
