goodridge
Which Induction Kit?
Hi all. Just wondered which is the best induction kit to get for my G60?At a reasonable price! :wink Also can someone explain the "RSR outlet" for me. Or can put up a link if this topic has already been covered before. Thanks
i think the general opinion of the g60 owners is to stick with the original airbox,and route a cold air pipe into it
i have also been advised in this way, standard air box with panel filter and big air feed, beats any aftermarked air filter.
Personally for my modded G60 I think it is far better to have an induction kit and heat shield, then remove the carbon cannister and have cold air feed cut into the brake air feed from under the front bumper through the carbon can hole.
The more cold air you can get into the supercharger the better especially if modified so induction kit every time as can suck in far more.
As for the RSR outlet. Darren at G-werks fitted one to mine when I had the charger rebuilt and uprated. It replaces the diffuser box on the charger outlet to a much larger pipe improving air flow from the charger into the engine and also allowing the charger outlet to be bored out to a much larger size.
Speak to Darren (g-man) from G-werks for a more in depth explanation.
