neo 0 Posted August 29, 2004 Hi Guys My 1800 16v is starting poor, first thing in the morning it start's but it's missfiring then it pick's up and is fine????????? It's had the normal stuff fitted, plugs, leads, cap, rotor, fuel filter. Even done the head gasket, but it was leaking water from the rear :( need some help Quote Share this post Link to post Share on other sites
aide 0 Posted August 29, 2004 Check cold start valve - blue connector on side of block. Make sure your mixture is right too, i had starting problems few months back and found was running very lean. Make sure your batteries in good nick too, replaced mine with a calcium jobby and am well pleased - bit pricier tho Quote Share this post Link to post Share on other sites
