dubbprince
Dash Removal
Hello...just wondering how the hell the dash comes out.
I've removed the nuts either side of the dash, i've removed all air ducts and relevant grills, switchs etc.
It looks like its being held at the top now by something.
As well as this...does anyone know what the best way to get the wiring out in one go?
I mean...can i undo the engine wiring from within the car and feed it through...or do i need to undo the engine wiring and feed that through the firewall?
I'll be labelling up all the wires too...just for the next person needing it. :wink:
Thanks for the help.
Sanj.
that got me too!!!
feel under the scuttle panel???? where the windscreen motor is, about a foot in from each side is a single nut, tricky to get to but you can reach it with a small spanner and/or small hands, i had to get sonia to do mine!
dubbprince,
if its anything like the g60 you can just unplug the engine loom from the fuse box and pull it through the bulkhead,shouldnt knead to lable it as the plugs will only fit in the corrasponding holes in the fuse box.
