Dub Style 0 Posted September 5, 2004 my Coilpack on my VR needs changing, was just wondering which is best out of the two systems for tuned engines, also is it possible to convert to either or is the engine different............and do crank position sensors only come on coil pack models. Quote Share this post Link to post Share on other sites
Robbo149 0 Posted September 6, 2004 AFAIK there's really no difference performance wise between the 2. I suppose the conversion could be done, but would probably involve other stuff too, such as ECU etc. so probably not worth it IMO. I'm sure there was a thread on here recently obout just this topic. Not sure about the crank sensor, or do you mean the Cam sensor? The dizzy engine has a drive wheel for the distributor instead of the cam sensor. HTH, Robbo Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 7, 2004 All VR6s have a crank sensor. The coilpack and Cam sensor does the same job as dizzy and hall sender but with the Coilpack you get a proper 3D timing map and much faster transient response times...... i.e. low tension to high tension amplfication is much faster in a coilpack. I think the coilpack was put on as part of an emissions tightening program on late VRs. Quote Share this post Link to post Share on other sites
sundodger 0 Posted September 13, 2004 Mines on its wayout too,whats the best place (price) to get them from? :? Are there any high performance ones out there? Quote Share this post Link to post Share on other sites
