biggrim 0 Posted May 14, 2003 Which type of boost guage do most of you have fitted, one that reads in PSI or BAR? Currently mine is a TIM Turbo boost guage and reads from -1 bar to 1 bar. Just wondering cause lots of posts refer to psi when talking about boost through the charger. Only had my G60 3 months so apokogies if this is a dumb question. :? Quote Share this post Link to post Share on other sites
Dubcharged 0 Posted May 15, 2003 I use a gauge which shows PSI, doesn't really matter which you have, just a matter of preference. Although if/when you go for a ported charger and 68mm pulley or smaller then you might wanna get a gauge which reads to 1.5bar/20psi or higher since you'll probably be making 1 bar boost or even a bit more! Quote Share this post Link to post Share on other sites
Banana Man 0 Posted May 15, 2003 I have a nomad boost gauge that reads upto 30psi :D and 2hg's negative boost it does the trick and I like the look of it!!! Quote Share this post Link to post Share on other sites
