potatonet 0 Posted September 20, 2004 ok so I ahve replaced everything inside the engine as fas as cooling goes, the oil cooler is the last thing I think. I have a g60 and it has had problems with water, right now it forms an air pocket somewhere dunno where. there is also oil in the water, the car doesnt overheat, but there is still oil there, I have replaced the headgasket less than 1500 miles ago, its copper and o-ringed, no its not the headgasket. anyway I was thinking about a eurosport oil cooler and hopefully that would work, how does it r-route the water? and where does the radiator type thing go? I have AC. dunno any help would be good. yea I am filling the system correctly. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 20, 2004 If the headgasket is now ok the only other place where water and oil can meet is the OE Heat Exchanger where the oil filter screws up to, have you changed that??? If not bypass it and fit a mocal oil cooler... Quote Share this post Link to post Share on other sites
