supercharged burgers
8 -
0 NeutralAbout supercharged burgers
supercharged burgers started following g lader charger
hello there sorry been away for so long, still have my corrado . slight problem with charger a slight knocking came from it a month ago so i took it off and split it , turned out that one of the spiral seals which sit in the groove had popped out and got pushed down by the side of the spiral. lucky enough it didn't blow up , it squashed over one side of the groove and put a hairline crack about 50mm along the spirall , what i'm looking for is either the pulley side of the charger or an idea on how to fix it please http://vagdrivers.net/forums/index.php?&showtopic=83287&pid=798483&st=0& this is the link to see the pics of the damage its slight damage so i'm hoping i can fix it with your help, i'll put pics up here but don't have camera with me at the mo hope ya can help guys
the f;'@ sunroof, my vw dealer is not very helpfull i need part no's for the rocker arm and sliding mech its attached to . or else get me part no's for the brain cos its wreacked trying to talk to the dealers . there's a pic of it on this thread :brickwall: :brickwall: :brickwall: thanks peeps
found braided pipe connected to something behind engine don't know the propper word for it. it has a valve on it also looks like there should be much bigger pipe coming off at the bottom, but heres the best bit the braided pipe is cut and a bolt put in the end so don't know where it goes , could do with some pics really thanks yuall :notworthy:
cheers getting it done soon as there's allways something
cheers all you fellow corrado peeps. getting the hang of this forum biz sorry about all the posts :confused4: ..but all your help on all my probs has been, t.o.t.r. :salute: "On my planet there's nothing but corrados" thanks again
i was at local stealers with sunroof prob it turns out its the rocker arm and guide that its attached to are worn, he needspart no for this cos it doesn't have part no "on my screen " does anyone have part no from old recipt or something . its the shiny bracket that stays still when your tilting it up, thanks all :clap:
how's it going out there, bought a g60 with dodgy sunroof tilt only, it was a nice car so that wasn't gonna put me off. tried to fix it this evening i found that one side wasn't down enough to let i slide , after a bit of adjustment it went back but was very stiff i then stopped halfway ,i closed sunroof and hay presto there's a scratch on the dodgy side.my ?is do i have to drop the whole sunroof track and all, or is there a easier fix don't mind dropping it but just taught i'd ask ????? :( all knowledge sent will be greatly appreiciated on me other planet :grin:
hope ya can help have prob with sunroof that tilts but won't go back it tries but something stopping it has someone come across this before and if you have how can i fix it
