stel g60 0 Posted October 10, 2004 does anyone know if this piece of s*** is available easily or is it another g60 only part that i have to order from a stealer and wait a couple months for it :mad: as you can see, i need a new one Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 10, 2004 get it from vag mate there not alot of wedge.. or just make somthing to blank the end of the pipe with. Quote Share this post Link to post Share on other sites
Banana Man 0 Posted October 10, 2004 take the top bity off so your left with the metal pipe get a length of fuel hose and blank it off it works a treat!!! Or you can just go out to the stealers as daz says and get it from there :D Quote Share this post Link to post Share on other sites
Henny 0 Posted October 10, 2004 you could even get really creative and remove that pipe entirely from the exhaust manifold, replacing it with a VW Lambda sensor which would then allow your original lambda location to be used for a wide band probe.... :idea: 8) Or, as Ant says, just shove a bolt into a bit of fuel hose with a couple of jubilee clips to hold it all together! ;) :lol: 8) Quote Share this post Link to post Share on other sites
stel g60 0 Posted October 11, 2004 VAG- no stock, makin something now :) Quote Share this post Link to post Share on other sites
