the_kernel114 10 Posted February 5, 2016 How much shipped to Canada? Postal code is v2p 1z1, British columbia Quote Share this post Link to post Share on other sites
kevwil1968 1 Posted February 6, 2016 hi dave - how much for both sides ? Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 6, 2016 (edited) What grade material are the new bits made of Dave ? Edit... Answered my own question t308 stainless steel Edited February 6, 2016 by delfinis38 Quote Share this post Link to post Share on other sites
Chargemeup 10 Posted February 6, 2016 Dave you're a legend! My door handle will never fail again! Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 7, 2016 How much shipped to Canada? Postal code is v2p 1z1, British columbia PM sent. Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 7, 2016 hi dave - how much for both sides ? £32 posted for both sides. Dave Quote Share this post Link to post Share on other sites
CRJSW 10 Posted April 25, 2016 Would love more info, how to buy? Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 30, 2016 Hi Dave - bought a kit off you a few years back that I am now getting around to fitting. A quick question - how long should it take to drill out the old hinge pin? I'm using a 3.5mm HSS-Titanium bit and have tried with both a Dremel and a heavy duty domestic drill, both mains powered, and it seems to be taking ages. Any advice appreciated. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted June 30, 2016 Hi Dave - bought a kit off you a few years back that I am now getting around to fitting. A quick question - how long should it take to drill out the old hinge pin? I'm using a 3.5mm HSS-Titanium bit and have tried with both a Dremel and a heavy duty domestic drill, both mains powered, and it seems to be taking ages. Any advice appreciated. I'm no expert but when I did mine, I didn't use the screws Dave supplied as they are too soft. I didn't drill the pin out but made the centre of the roll pin large enough to take a tap.. Can't remember the size maybe 2.5 or 3 mm. I screwed the tap in about 5 to 7 mm enough to grip then pulled the pin out.. Think you have to use the pins again so don't drill them out unless you have spares. Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 30, 2016 I have spare pins, so that's ok. Hmm - might need to get some small taps then. Will have a look. I have a set of hardened screw extractors but they are slightly too big to fit. Thanks. I'm no expert but when I did mine, I didn't use the screws Dave supplied as they are too soft. I didn't drill the pin out but made the centre of the roll pin large enough to take a tap.. Can't remember the size maybe 2.5 or 3 mm. I screwed the tap in about 5 to 7 mm enough to grip then pulled the pin out.. Think you have to use the pins again so don't drill them out unless you have spares. Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 1, 2016 Hi Dave - bought a kit off you a few years back that I am now getting around to fitting. A quick question - how long should it take to drill out the old hinge pin? I'm using a 3.5mm HSS-Titanium bit and have tried with both a Dremel and a heavy duty domestic drill, both mains powered, and it seems to be taking ages. Any advice appreciated. Sorry for the late reply. I don't advise drilling the pin out, my advice is to pop the back off the pin housing and push the pin out from the back, it's detailed in my install guide if you have it handy. If not I can send it to you but need an email address. Dave Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 1, 2016 @dave - PM sent with email. Cheers, the instructions are probably in my big "box of car paperwork and receipts", but I can't find them. Quote Share this post Link to post Share on other sites
Storm Guy 0 Posted July 5, 2016 HUGE Thanks Dave, kit arrived promptly this morning and I now have a working drivers doors handle! Awesome service as ever mate! Quote Share this post Link to post Share on other sites
Chris Smith 0 Posted July 12, 2016 Just fitted my new door handle repair kit. Very well made, just the job. Had a right nightmare with the pivot pin, ended up drilling out half the metal from the broken striker plate around it. Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 12, 2016 Just fitted my new door handle repair kit. Very well made, just the job. Had a right nightmare with the pivot pin, ended up drilling out half the metal from the broken striker plate around it. I've had to do that in the past but I've got good at swapping them now. Quote Share this post Link to post Share on other sites
slashcann100 10 Posted July 19, 2016 Are these kits still av, i need a drivers door handle kit Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 20, 2016 Are these kits still av, i need a drivers door handle kit Yes they are, drop me a PM. Thanks Quote Share this post Link to post Share on other sites
mansell.ellis 10 Posted August 21, 2016 Hi Dave. Could you please send a drivers side kit to me please. First time on this forum so not sure of the process from here. Rgds, Mansell Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 21, 2016 Hi Dave. Could you please send a drivers side kit to me please. First time on this forum so not sure of the process from here. Rgds, Mansell Mansell, I'll drop you a private message with payment details. Dave Quote Share this post Link to post Share on other sites
Wendy 0 Posted May 29, 2017 Dave hi, Are you still doing these repair kits. I need one please for the Passenger Door. Thanks Wendy Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 29, 2017 Dave hi, Are you still doing these repair kits. I need one please for the Passenger Door. Thanks Wendy Hi Wendy, Yep still supplying these, I'll drop you a PM with payment details. Dave Quote Share this post Link to post Share on other sites
nutter driver 0 Posted July 3, 2017 Morning, just had a call from the missus saying she's just broken the drivers door handle, so im guessing im going to need a kit please! Can you let me know total inc postage etc, and ill get it sent over! Cheers. Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 5, 2017 Morning, just had a call from the missus saying she's just broken the drivers door handle, so im guessing im going to need a kit please! Can you let me know total inc postage etc, and ill get it sent over! Cheers. PM sent. Quote Share this post Link to post Share on other sites
Janika 10 Posted September 19, 2018 Hello I could do with handle repair kit for 94 16V Quote Share this post Link to post Share on other sites
daves16v 1 Posted September 19, 2018 Hello I could do with handle repair kit for 94 16V PM sent. Quote Share this post Link to post Share on other sites
