Heardy 0 Posted October 14, 2004 Had it pressure tested today and regassed and it seem's to be working fine upto now :) I've just got a couple of questions to someone who's got a C with aircon The actual pump only opperate's when you press the max button is this correct ? What is the function of the min button i can hear something opperating inside the heater box jm just a bit curious really :roll: Also the cooling fan's don't opperate when the aircon is switched on, as far as i'm aware one of the relay's under the bonnet switch the fan on but which one :roll: Any other info about it would be appreciated Cheers Jason Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted October 14, 2004 The air-con should work with either MAX or MIN. The difference is the re-circ flap opens or closes in the air-box. MAX is when the flap is closed (i.e drawing cold air from in the car). MIN is drawing air from outside. Jay Quote Share this post Link to post Share on other sites
Heardy 0 Posted October 14, 2004 O right i see.The other problem is i'm not sure if the min and Max button's are connected correctly as when i replaced the heater matrix the connection's on the back of the switch's came off and i'm not sure if i've mixed them up :roll: Quote Share this post Link to post Share on other sites
MoonlightVR 0 Posted October 14, 2004 Sounds like you've mixed the wiring up on the mIn and max settings based on your description above. Quote Share this post Link to post Share on other sites
VR6 0 Posted October 14, 2004 Not quite a problem if you've got it working! Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 15, 2004 just in time for...winter to :D Quote Share this post Link to post Share on other sites
dinkus 10 Posted October 15, 2004 just in time for...winter to :D It's actually very useful in winter cos it dries the air and demists your windows quickly! ;) Quote Share this post Link to post Share on other sites
