dubweiser
lambda probe
Ive just about ripped every last hair out of my head trying to find my cars crappy idling/running problem and it seems the only thing left is to replace or at least check the lambda probe.It is a 93 2litre 16v.Can someone tell me where exactly it is located and is there a way of testing it please.Help is mucho appreciated......
Yep, the connector is clipped to the rear engine mount and the probe itself is infront of the cat. I don't know if the 16V uses a 3 or 4 wire probe but to test it you need to prod a meter probe in the signal wire (usually white) and the other probe to earth. When the engine is hot, the volt meter should fluctuate rapidly. If it just sits there at 0.45V, the probe is dead.
thanks for that.But that reminds me does anyone know how many wires my probe should have as the guy at ECP asked me this on the fone and im not sure
I was advised not to buy a generic 2 or 4 wire Lambda by my mechanic friends.
If I remember correctly a genuine one was about £60 from the stealers, once I negotiated some discount for being in the CCGB.
oh yes and my cat keeps stinkingDoes this point to the lambda being Sha**ed
If it smells like rotten eggs, it is working..
Gavin
