bighands 0 Posted November 9, 2004 As the title says! Got audiobhan 6x9's and the head unit is not doing them justice! They are 215w RMS, i dunno if this is each or between them, most likely between i should think, but the whole RMS and PMPO confuses me! so any one recommend any good amps, not silly prices but good quality all round jobbie, prices ect? the head unit says 4x45w on the front, but think that is proberly PMPO?? Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 9, 2004 what model number are the 6x9's? Quote Share this post Link to post Share on other sites
bighands 0 Posted November 9, 2004 ABF39T a quality buy of mine, had em bout 4 months now, and just want MORE!!!! Quote Share this post Link to post Share on other sites
Christoph 0 Posted November 10, 2004 Genesis amps are supposed to be pretty good, and not too pricey. Chris Quote Share this post Link to post Share on other sites
mrbeige 0 Posted November 10, 2004 Genesis amps are supposed to be pretty good, and not too pricey. Genesis Profile Two - 2 x75W Rms which is plenty.... £199 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 10, 2004 The Profiles are pretty good and very compact for a nice stealthy install. They have built in fans but run a hybrid class D so don't get that hot anyway. If you can stretch to a Genesis series III two channel (try ebay etc) , you'll get a much better sound - imo of course :) Quote Share this post Link to post Share on other sites
bighands 0 Posted November 10, 2004 Nice one lads, cheers! But why only 75 watts RMS? surely i want 110ish? :roll: Quote Share this post Link to post Share on other sites
atif 0 Posted November 11, 2004 I am running the exact same 6 by 9's and i am running a Kicker 300.4 amp to run them. they sound awesome. at 75 watts RMS they sound sweet. there is no need to run them at full power!! if you want then you can run them at more power!! but i would definetly reccommend the amp!! Thanks Atif Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 11, 2004 Nice one lads, cheers! But why only 75 watts RMS? surely i want 110ish? :roll: Don't let that you put you off.... Genesis are known to be conservative with their outputs. The Series IIIs deliver double the rated outputs and the Profiles give more than quoted too.... Quote Share this post Link to post Share on other sites
mrbeige 0 Posted November 12, 2004 Don't let that you put you off.... Genesis are known to be conservative with their outputs. The Series IIIs deliver double the rated outputs and the Profiles give more than quoted too.... He's not wrong..... :D Quote Share this post Link to post Share on other sites
coolrado 0 Posted November 12, 2004 just to clear up the difference between RMS and PMPO (also known as argos watts) PMPO The term PMPO is actually a cheat. It means peak music power output and it's the maximum of power that a speaker can handle. Actually, if you feed an 80W PMPO rated speaker with 80W of power it will blow in less than a second. Power has to be specified in watts RMS (which is 0.707 of the true voltage). Output power (W) is voltage (V) multiplied by current (I). W=V*I Voltage and current are measured as RMS values. Than you can calculate power. A speaker rated 80W PMPO is nominally 4W RMS rated. When you divide the PMPO value with 20 you will get the REAL rated power. For example, lets take an Aiwa stereo, there is a sticker at the front which screams 450Watts PMPO. Well, when worked out it is actually 23Watts RMS, big difference. PMPO is fake, it's cheating. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 12, 2004 Yep.... and the "real world" short term power peak is 1.414 x the RMS value. It's slightly different with car amplifiers as they deliver more or less depending on power supply voltage these days. Genesis use a seperate power supply per channel on the twin mono 3 series and a PSU per stereo pair on the 4 channel S 3......and according to my test cert, I'm getting 4 x 101W RMS, or 4 x 141W pre clip Maximum @ 12V. PMPO I'm not even bothering with as it's purely academical!! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 12, 2004 PMPO (also known as argos watts) :lol: Quote Share this post Link to post Share on other sites
