greegs 0 Posted November 10, 2004 Hi will the above wheels fit on my corrado vr6 ? Been offered a set of 4 for £150 with good tyres. Was actually looking for a set of 15" steel wheels and tyres so I can take my TT rims off over the winter, but came across these and think they are a bargain if they fit ! Not to sure what the offset is but I am assuming the pcd is 5 x 100 ? Any help appreciated. Quote Share this post Link to post Share on other sites
Phil K 0 Posted November 11, 2004 fairly certain they will fit should be able to find out on http://www.seatcupra.net HTH Quote Share this post Link to post Share on other sites
hutchyvw 0 Posted November 11, 2004 the wheels will be spot on mate they are def a 5/100 the centre bore is also perfect 57.1 and the offset won't really matter in that size. however the tyres are likely to be a 205/55/16 which is quite a bit to baloon like for the corrado, you'd be better with 205/45's. still cheap tho. hutchy. p.s check if the bolts are the same, the leon will have a 14mm bolt so you'll need your 12mm bolts of the corrado for them. Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted November 11, 2004 5 studs are 14mm, 4 studs are 12mm....i'm pretty sure? Therefore the Leon bolts will be spot on. Quote Share this post Link to post Share on other sites
greegs 0 Posted November 11, 2004 Thanks for help guys :) Quote Share this post Link to post Share on other sites
