Kevin Bacon 5 Posted February 14, 2005 Could this be the infamous 'worn dizzy' thing? Does the G60 ECU support data logging? You need to have a look at the fuelling map and knock tables. Quote Share this post Link to post Share on other sites
andycowuk 0 Posted February 15, 2005 good try kev, but i been there already.....new dizzy I dont know about the data logging, but its std chip thats in. Quote Share this post Link to post Share on other sites
jezzaG60 0 Posted February 15, 2005 Standard chip you say? Are you running the stock pulley on the charger too? Either way with the mods you have i would imagine your flowing a fair bit more air which in turn is gonna need more fuel. I'd say you want to get it on the rollers with a gas analyser and see what the mixture is up to.... then get one of those nice SNS chips. Alternatively get one of those Air fuel guages which hooks onto your existing Lambda... they are far from ideal but they will at least give you some idea of when your car is running rich or lean.... i know back when i hooked one of these up it helped me find many little gremlins including bad earths, a broken ide switch and gave me a worrying look at the imfamous "dighifant delay"! Quote Share this post Link to post Share on other sites
andycowuk 0 Posted February 15, 2005 yes, its a stock pulley. Last time it was on the rollers, the gas analyser said lean up to about 4k, changing to rich up top - most probable cause for this is digilag. I have an afr gauge in the car, and it indicates that things are ok...... Quote Share this post Link to post Share on other sites
W3RKD 0 Posted February 16, 2005 andycowuk said: yes, its a stock pulley. Last time it was on the rollers, the gas analyser said lean up to about 4k, changing to rich up top - most probable cause for this is digilag. I have an afr gauge in the car, and it indicates that things are ok...... Andrew, a in-car afr gauge will only tell you when the engine is about to die. these are not accurate enough for setting your engine up my friend. either take it to someone with a wide-band or alternativley invest in a LM1. this piece of equipment will read all of your afr with complete accuracy. Quote Share this post Link to post Share on other sites
