Ice White Socks
Seat base fitting
Hi,
Will be finally fitting bolster/ seat base and heated seat element this weekend. Obviously the bolster should be straightforward if I follow Mssr Haywires guide. Anyone got any advice on fitting the foam base? or is it just dead easy :?:
Foam base is even easier!
Just unhook the material (cardboard strip at the rear and metal eyelets at the front), whip out the bum foam and stick the new one in. Obviously there will be some wiring to do on yours, but it's all easy stuff.
