kebabman
Rogue plug
Just fitted an uprated headlight loom to my VR, and while I was under the car I noticed a 3(maybe 4)pin yellow plastic plug that was just hanging down by wires in the driver side bumper recess. It's on the far side infront of the wheel. Anyone know what this is and if it's supposed to be connected? Haven't noticed any problems and all the lights work. :?
Cheers :)
Could be the a ambient temp sender plug. Des the MFA report outside temp OK?
If everthing works OK, it might just be an accessory not used on UK cars that dropped down for some reason?
I haven't noticed any problems with the MFA's reading of the outside temp.....might be headlight washers as I didn't know we had them until just now :oops: so maybe they're not working :lol:
Will try and get a picture of the offending plug, easier than describing it.
Cheers for the advice so far lads :)
Finally took a pic, and think I've sussed what it is at the same time :roll:
This is the plug....what's the plastic canister thing to the right?
Goes here..... is this the external temp sensor?
if its the same as the G60, then yes thats your external temp sensor, and the plastic canister is your Carbon Canister, which I believe is used to reduce emissions (think theres a fuel breather pipe goes into it, and some other stuff...) I've removed mine so I can have a cold air feed pipe to the airbox through the space left by it - theres quite a few threads about this :)
