coullstar
8 x 15" ET32
The et is going in your favour being 32, they'll want to sit in towards your struts, so you should be able to put spacers on to clear them.
They won't hit the front struts but they may rub on the rears depending how low you are, but I doubt it you use 205 tyres. My 8 x 17s with 215 tyres go on OK with ET35 but they ever so slightly catch the rear arch over big bumps but there's enough room in there to take the offset down to 40 without rubbing the rear spring plates.
