Dub Style 0 Posted January 5, 2005 I'm in the process of investing money into a set of these but i've got one question for those running RS301's looking at your car do you think its possible to run wider outer rims with arch mods. i know as standard they come with an inch and a half rim, but is there enough space to go wider maybe 2.5? Quote Share this post Link to post Share on other sites
OSV 0 Posted January 5, 2005 Not without arch mods, if your car is v. low it may need slight arch mods with the standard RS 301s. It is ride height dependant though if your high or firm enough then the arch may never come into contact with the tyre. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted January 6, 2005 I had to roll the front and rear fenders to tuck the 7.5's...and the fronts still rub at full turn. Quote Share this post Link to post Share on other sites
OSV 0 Posted January 6, 2005 For comparison, with the same wheels I had no arch mods but the car doesn't ride as low. Quote Share this post Link to post Share on other sites
Dub Style 0 Posted January 6, 2005 Oettinger SLC, what size are your outer rims. Quote Share this post Link to post Share on other sites
OSV 0 Posted January 6, 2005 BBS RS 301s are all PCD 5x100 ET 33 7.5x17 and the outer rim only sticks out about half an inch from the face of the wheel. The dish curves back in first creating the look of extra depth. With your proposed 2.5" dish you would have a 9.5" wide wheel with an ET of 9 and it would require serious arch mods. Quote Share this post Link to post Share on other sites
Dub Style 0 Posted January 6, 2005 Somthing like completely cut away the flat edge on the quarters and wings?? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 6, 2005 I'll be taking my rears out to 8.5", I'll let you know when I order the rims. Quote Share this post Link to post Share on other sites
Dub Style 0 Posted January 6, 2005 I'll be taking my rears out to 8.5", I'll let you know when I order the rims. :) sorted!! Quote Share this post Link to post Share on other sites
RS VR6 0 Posted January 7, 2005 Somthing like completely cut away the flat edge on the quarters and wings?? You need more than that. I have a friend that has 9's in the front and 9.5's in the rear. You will need to pull the arches out quite a bit. 8.5's you can probably get away with some minor work. Quote Share this post Link to post Share on other sites
vwfastg60 0 Posted January 8, 2005 BBS RS 301s are all PCD 5x100 ET 33 7.5x17 and the outer rim only sticks out about half an inch from the face of the wheel. The dish curves back in first creating the look of extra depth. With your proposed 2.5" dish you would have a 9.5" wide wheel with an ET of 9 and it would require serious arch mods. The 9.5 on an rs301 does require alot of work to the rear... this is a pic of what 9.5 in the rear and non modded arces looks like. And to drive the car sitting at that level is impossible The front fenders had to be pulled 1inch to fit the 9. the rear in order to lower the car and not rub will almost need to be pulled 2inch Quote Share this post Link to post Share on other sites
RS VR6 0 Posted January 9, 2005 BBS RS 301s are all PCD 5x100 ET 33 7.5x17 and the outer rim only sticks out about half an inch from the face of the wheel. The dish curves back in first creating the look of extra depth. With your proposed 2.5" dish you would have a 9.5" wide wheel with an ET of 9 and it would require serious arch mods. The 9.5 on an rs301 does require alot of work to the rear... this is a pic of what 9.5 in the rear and non modded arces looks like. And to drive the car sitting at that level is impossible The front fenders had to be pulled 1inch to fit the 9. the rear in order to lower the car and not rub will almost need to be pulled 2inch Russ is a froot... :hic: Quote Share this post Link to post Share on other sites
vwfastg60 0 Posted January 9, 2005 BBS RS 301s are all PCD 5x100 ET 33 7.5x17 and the outer rim only sticks out about half an inch from the face of the wheel. The dish curves back in first creating the look of extra depth. With your proposed 2.5" dish you would have a 9.5" wide wheel with an ET of 9 and it would require serious arch mods. The 9.5 on an rs301 does require alot of work to the rear... this is a pic of what 9.5 in the rear and non modded arces looks like. And to drive the car sitting at that level is impossible The front fenders had to be pulled 1inch to fit the 9. the rear in order to lower the car and not rub will almost need to be pulled 2inch Russ is a froot... :hic: What is a froot???? somone drunk???? Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted January 9, 2005 think he means fruit...~? Quote Share this post Link to post Share on other sites
Dub Style 0 Posted January 9, 2005 I had been looking at these wheels also they are 8x17 with a flat dish, trouble is with adapters they will be et10 so not much joy!! Edited sorry wrong pic!!, i can pic these wheels up for about 500 quid and spend a grand on arch work, either that or pay 1500 for rs301's, Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 9, 2005 Or you could just wait a while until I've done mone and then decided to sell them. (especially if you're offering £1500!!!) Quote Share this post Link to post Share on other sites
Dub Style 0 Posted January 9, 2005 PhatVR6, SGi have got a set for sale and thats what their asking, honestly i did think that was a lil steep for 17's and i was in two minds about buying them.......i've now decided to leave it and consider other options.........i could cough up about a grand but thats my limit...either that or struggle like a mutha with the beemer wheels Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 9, 2005 ah well, supergolfs........fantastic prices.........I'm amazed they sell anything. Quote Share this post Link to post Share on other sites
AmbisoniK 0 Posted April 9, 2006 BBS RS 301s are all PCD 5x100 ET 33 7.5x17 and the outer rim only sticks out about half an inch from the face of the wheel. The dish curves back in first creating the look of extra depth. With your proposed 2.5" dish you would have a 9.5" wide wheel with an ET of 9 and it would require serious arch mods. Any idea what the ET would be on a 1" dish (8" rim) ? would an 8" rim fit straight on without arch work ? i'm in wheel limbo @ the moment,dunno if i should stick with the RS's or sell up & go for a set of 8x16 Compomotive MO's :| Quote Share this post Link to post Share on other sites
Furkz 0 Posted April 9, 2006 BBS RS 301s are all PCD 5x100 ET 33 7.5x17 and the outer rim only sticks out about half an inch from the face of the wheel. The dish curves back in first creating the look of extra depth. With your proposed 2.5" dish you would have a 9.5" wide wheel with an ET of 9 and it would require serious arch mods. Any idea what the ET would be on a 1" dish (8" rim) ? would an 8" rim fit straight on without arch work ? i'm in wheel limbo @ the moment,dunno if i should stick with the RS's or sell up & go for a set of 8x16 Compomotive MO's :| reading previous comments sugguests it depends on the drop of the vehicle mate... 8's would look cool though Quote Share this post Link to post Share on other sites
AmbisoniK 0 Posted April 9, 2006 Yeah i'm not to keen on the 1/2 " lip look,just doesnt quite look right,but i'm worried if i do that i won't be able to slam the car low without arch work. would probably get the centres sprayed the same colour as the car while i'm @ it if i take that route.. Quote Share this post Link to post Share on other sites
carpoid 0 Posted April 10, 2006 OSV put some 8' rears on his without any arch work. But if you want to go low like RSVR6, i'm pretty sure he had his rolled and even pulled out a touch. Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted April 10, 2006 There's a set 0f 8x17 BBS RS on Oxford Editions forum. Asking price is a ridicious £2000 though Quote Share this post Link to post Share on other sites
pkripper 0 Posted April 10, 2006 I had been looking at these wheels also they are 8x17 with a flat dish, trouble is with adapters they will be et10 so not much joy!! Edited sorry wrong pic!!, i can pic these wheels up for about 500 quid and spend a grand on arch work, either that or pay 1500 for rs301's, There was a good straight set of RS303's on E bay that ended this week (a guy from E38) that sold for £870 delivered. You could have striped them down and polished the front lips for virtually nothing and got steel outers for the rears for £100 eachish. 4x100, but straight 5x100 301's would be the same. Quote Share this post Link to post Share on other sites
AmbisoniK 0 Posted April 10, 2006 OSV put some 8' rears on his without any arch work. But if you want to go low like RSVR6, i'm pretty sure he had his rolled and even pulled out a touch. Arch work it is then unless i stick to the standard 1/2" lip - may look better with the centres colour coded. i basically want the wheels sitting exactly like this - Quote Share this post Link to post Share on other sites
