Dub Style
Difference with G60's and VR's
is the difference between the two just with the engine or are they different designs in chassis, i have a friend who has a g60 that has had loads spent on it, if a vr conversion was to be done will every thing bolt up as normal or are engine mounts etc in different place.
VR uses different driveshafts, gearbox, hubs, wishbones, struts, but the engine mounts and wishbone mount points are the same (afaik). If you want to do the switch, you need the lot..
