Dub Style 0 Posted January 9, 2005 is the difference between the two just with the engine or are they different designs in chassis, i have a friend who has a g60 that has had loads spent on it, if a vr conversion was to be done will every thing bolt up as normal or are engine mounts etc in different place. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 9, 2005 Nope, the VR6 is based on mainly Mk3 stuff, Ie the 'plus' suspension, engine mounts etc... Quote Share this post Link to post Share on other sites
Dub Style 0 Posted January 9, 2005 is the g60 based on the same? Quote Share this post Link to post Share on other sites
Furkz 0 Posted January 10, 2005 G60 based on MK2 Quote Share this post Link to post Share on other sites
Storm 0 Posted January 10, 2005 Basic bodyshell and all suspension pick up points are the same. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 10, 2005 VR uses different driveshafts, gearbox, hubs, wishbones, struts, but the engine mounts and wishbone mount points are the same (afaik). If you want to do the switch, you need the lot.. Quote Share this post Link to post Share on other sites
