Dub Style
How do i remove the ABS system?
Over time i've had quite a few problems with the ABS system on my VR either its the pump or a sensor playing up and i now want to remove the system is this possbile?, or will i have to take out the braking system out of a g60 and fit into mine.
Tricky. Technically, once the car has ABS fitted at the factory, it'll fail it's MOT if it's not working, even if it's been completely removed..
I heard g-man removed the ABS from the Golf I sold him. Not too difficult to remove all traces of it.
I am sure the 'if it's fitted, it has to work ' rule would apply at MOT time.
Gavin
Gavin
yes i did remove the abs from the golf.. i had to replace the peddle box with a corrado one etc not to bad to do and makes the brakes soo much nicer espically with the bias valve fitted along with complete internal braided hoses. :lol:
