VW Corrado 16V 0 Posted January 24, 2005 Mine “Out door handle is broken”. I can’t open the door, but the lock works. I search the “old themes” and understand that the Passat (35i ?) handle can be used. I want to stay with mine (door handle) and only to fix the mechanism? Is this possible? So I need the rear handle from the Passat (left or right?) – can I use the front ones? I have also auto up windows (cables on it)? Thanks Quote Share this post Link to post Share on other sites
coolrado 0 Posted January 24, 2005 daves16v does a repair kit for these, the passat rear handles are de-locked but if you want to keep the locks daves kit is the way to go http://the-corrado.net/.archive/forum/viewtopic. ... ght=repair Quote Share this post Link to post Share on other sites
VW Corrado 16V 0 Posted January 24, 2005 daves16v does a repair kit for these, the passat rear handles are de-locked but if you want to keep the locks daves kit is the way to go So if I use the Passat handles I will not able to lock it? Can I use only the mechanism? I can’t buy it from daves16v because I’m from other country… Quote Share this post Link to post Share on other sites
theRuler 0 Posted January 24, 2005 what country are you in? Quote Share this post Link to post Share on other sites
coolrado 0 Posted January 24, 2005 the passat handles are from the back doors so have no lock barrels i have these on my car and use the alarm to lock and unlock the car im sure dave can still supply the kits whatever country you are in as they are very small Quote Share this post Link to post Share on other sites
VW Corrado 16V 0 Posted February 1, 2005 I buy handle from Passat, but it doesn’t work. Can’t open the door with it. :?: (rear handle) Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 1, 2005 VW Corrado 16V, I posted a pair to the US a few months back, where are you? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 2, 2005 I buy handle from Passat, but it doesn’t work. Can’t open the door with it. (rear handle) You will also need the mechanism to go with this! Quote Share this post Link to post Share on other sites
