billinjah 0 Posted February 12, 2005 my passenger handle comes away from the door when you pull it just under the lock barrel it still works fine though is there a screw inside the door that holds the handle down? Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 12, 2005 The screw is just inside the door. Quote Share this post Link to post Share on other sites
billinjah 0 Posted February 12, 2005 is that the only one? Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 12, 2005 Yep. If you need to remove the handle take the screw out, grab the handle and push it toward the front of the car, it will move about 10mm. Then ease it away from the door starting at the lock end. Quote Share this post Link to post Share on other sites
billinjah 0 Posted February 12, 2005 how strange mine is moving away from the door then? ill investigate in the am! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 13, 2005 Hmmm... sounds like you may have had an attempted break-in..? Quote Share this post Link to post Share on other sites
