emmafwa 0 Posted February 14, 2005 Can someone tell me if I should stop worrying? When I drive round a sharp bend (it has to be quite sharp), left or right something beeps??? It seems to come from the dash area, no warning lights come on and the performance doesnt seem to change? Has anyone else had this problem? Is it a problem? Edited title to make it a bit more relevant than just "help!!!" VR6 Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 14, 2005 Check your oil!! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 14, 2005 That's the oil surge warning buzzer and yes it is a problem as it basically means your head, crank and piston rings are momentarily starved of oil. Quote Share this post Link to post Share on other sites
emmafwa 0 Posted February 14, 2005 Cheers will do so asap. Emma Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted February 14, 2005 my mate had this problem, oil was leaking out of the front sensor, nearly emptied the whole lot over a couple of weeks. replacement sensor cost under a tenner, puls we did an oil change at the same time to be on the safe side. Quote Share this post Link to post Share on other sites
CorradoWannabe 1 Posted February 24, 2005 I've had this too and posted a message here :) it was just that the oil level was low - topped it up and that sorted it :) Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted February 24, 2005 Anyone know where a baffled sump can be had from? Quote Share this post Link to post Share on other sites
Jim 2 Posted February 24, 2005 I know Darren @ G-Werks can source the Schrick baffled sumps for the G60 - I assume they produce one for the VR6 and that Darren could order it in for you? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 24, 2005 You can get a sump gasket/baffle from VAG for the 4 Cyls which works with the original sump but I think you'll have to get an aftermarket for the VR... Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted February 24, 2005 You can also get the sump gasket baffle from GSF car parts for the 4 cylinder. That'll do the trick. However your profile doesn't say whether you have a 4 cylinder or a VR6 Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted February 24, 2005 You can also get the sump gasket baffle from GSF car parts for the 4 cylinder. That'll do the trick. However your profile doesn't say whether you have a 4 cylinder or a VR6 You didn't read his signature then ;) Quote Share this post Link to post Share on other sites
JimSTORM 0 Posted February 24, 2005 ihad the exact same thing happen to me a few weeks back, my oil filter had a crack in it and i had lossed alot of oil.. Quote Share this post Link to post Share on other sites
Guest Posted February 24, 2005 50mph round roundabouts generally gets it beeping too 8) Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted February 24, 2005 Andi - That looks more like where a mod has edited it, namely VR6 not an actual signiture but your the boss and I may be wrong!!!! Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted February 24, 2005 Trust me Blue_Joemy signature's been like that for nearly a year. :) Not to worry, I've done the same thing myself. I've seen baffled sumps for other cars selling for £300 or more! Surely it isn't a big job baffling your existing one? Quote Share this post Link to post Share on other sites
