Flo 0 Posted February 27, 2005 Ok, so I had nothing to do today, so I thought i'd find the cause of a rattle in my door trim. Took the door card off and hey presto, the speaker was rattling. Bolted this down securely, and problem solved. However, managed to know the door pin rod out of the lock and cant bl**dy see where its supposed to go. the access hole is tiny! Do I have to take the lock out to put this back in? Also, the electric mirror adjuster broke in my hand as i took it out, with tiny springs and plastic going everywhere. No idea how to put it back together and i think a spring went awol anyway. Anyone know if these are still available from the stealers, or anyone got one spare? ARRRGGHH! Fixed one problem only to create myself 2 more!!!! Cheers all, hope you had a good weekend. Quote Share this post Link to post Share on other sites
andycowuk 0 Posted February 27, 2005 know how you feel - I broke my drivers door handle (again) and now the car goes like stink! Quote Share this post Link to post Share on other sites
Rossco 0 Posted February 28, 2005 Flo said: However, managed to know the door pin rod out of the lock and cant bl**dy see where its supposed to go. the access hole is tiny! Do I have to take the lock out to put this back in? Taking the lock out is easy mate, its only 2 allen key bolts, 6mm if i mind right. I cand quite think off the top of my head which rod your talking about but ive had my lock and door handle off and it wasnt a lot of grief to put it back in, if this is no use then pics might be of some use Flo said: Also, the electric mirror adjuster broke in my hand as i took it out, with tiny springs and plastic going everywhere. No idea how to put it back together and i think a spring went awol anyway. Anyone know if these are still available from the stealers, or anyone got one spare? Head to the scrappies and you can find them on passats, ive got a few from them as its always worth having spares. :D Quote Share this post Link to post Share on other sites
kangaroo 0 Posted February 28, 2005 Did the same with mine! You can fit the door pin back in without taking the whole lock out, but its fiddly. It fits into the small white lever inside the door, the right-angled end-bit clips into a small hole in the lever. Difficult to explain, but with a torch and some wiggling you can fix it. Quote Share this post Link to post Share on other sites
Flo 0 Posted February 28, 2005 cheers, I'll try putting the pin in back in tonight. Phoned a couple of breakers and no one had a passat, so I had to go to the stealers! £45, Jeez!!! Suppose it was a bit of a bonus that they had one in stock though. Quote Share this post Link to post Share on other sites
Flo 0 Posted March 1, 2005 Well, tried to fit the mirror adjuster that i bought from the stealers tonight, and guess what its faulty. It lights up, but thats about it. Hmpf. Quote Share this post Link to post Share on other sites
