DaveVR6 0 Posted April 6, 2005 the backlight on my digital mileage display doesnt work, will this be the actuall display itself? also I havent got any light behing my heater controls at night, Im guessing they should light up?? many thanks D Quote Share this post Link to post Share on other sites
dubster82 0 Posted April 6, 2005 bulbs gone id say. both of them. tho i dont think you can change the one in the heater controls.... :cry: Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted April 6, 2005 Is it jus a blub behind the mileage display then?? Quote Share this post Link to post Share on other sites
woody 0 Posted April 7, 2005 You can change the bulb behind the heater sliders but it involves, 1. Remove both sliders and heater speed knob 2. Removing heater panel 3. Remove power connection (white connector) 4. Remove fan speed connector (move up towards the windscreen out of its slot) 5. Check that you have some power going to the white connector (Fuse?) 6. Using a small screwdriver pry "carefully" the white backing away from the black part of the controls. 7. Use small screwdriver to push the two connectors within the white panel where the bulb is and the bulb will come out. Go to a scrappie find a golf and get a another bulb. (Try to check it somehow with a battery) 8. When putting it back together just use some glue to reattach the white panel to the black panel Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted April 7, 2005 Or, as DM's car looks a new shape... Pull off centre heater dial, remove bulb enclosure, there's the bulb ;) Take to Maplins and they'll find a suitable replacement. And your mileage display could be a blown bulb, or a dodgy connection. You'll have to pull out the speedo binnacle (instructions in the DDI dials thread I think) and its a simple screw-cap to remove to get to the bulb. Might just be loose though. Quote Share this post Link to post Share on other sites
Walesy 0 Posted April 7, 2005 eh??? the heaters...have lights??? :oops: ....on the late spec interior??? hmmmmm im guessing that my bulb was gone when i bought the car then!... Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted April 7, 2005 Yes, very BAD lighting (one weedy bulb serves all three dials via a very inefficient light-guiding-plastic-thingy, but yeah, they do illuminate :) Quote Share this post Link to post Share on other sites
Tom_VR6 0 Posted April 7, 2005 I wonder if you could try and get a stronger bulb (without melting the plastic that is)? Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted April 7, 2005 Cheers Andi, will give it a look tonight Quote Share this post Link to post Share on other sites
Walesy 0 Posted April 7, 2005 just had a go..and snapped the plasstic bulb in the middle dial! Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted April 8, 2005 I managed it without breaking anything! Does anyone know if you can get the colour piece of plastic that sits on the inside (that is currently green) in any other colour?? Im guessin not but jus thought id ask. Quote Share this post Link to post Share on other sites
fla 9 Posted April 8, 2005 Quote Does anyone know if you can get the colour piece of plastic that sits on the inside (that is currently green) in any other colour?? If you mean the thin piece inside the front cover panel, the easiest is to trace it out on a red/blue/any colour sheet and replace it. If you mean the green spider behind the controls when you take them out, the only option is a set of coloured leds. Someones done a good writeup on this (cant remember who) so "use the search" :wink: Quote Share this post Link to post Share on other sites
Walesy 0 Posted April 8, 2005 Quote Does anyone know if you can get the colour piece of plastic that sits on the inside (that is currently green) thats the bit ive snapped...so it would be handy if u can replace them! Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted April 8, 2005 fla said: If you mean the thin piece inside the front cover panel, the easiest is to trace it out on a red/blue/any colour sheet and replace it. If you mean the green spider behind the controls when you take them out, the only option is a set of coloured leds. Someones done a good writeup on this (cant remember who) so "use the search" :wink: Thats a good idea! Quote Share this post Link to post Share on other sites
