contender
Belt Tensioner VR6
Just had a tow in off M25 with a belt tensioner fell to pieces. :( Heard a few bangs under the car as bit fell off. Overheated and ignition warning light on. Is it a DIY job to replace the tensioner? ?Has anyone any tips on how to proceed cost Etc.
Thanks in advance
Tensioner costs about £60 and the belt is about £20, not sure on the exact process of installation. Id take it to a garage and make sure everything else is right.
it is a DIY job to replace it...but as tekara has suggested just in case any other damage has been done take it to a garage for a once over.
Well the cause is problem down to a warn / seized bearing in the tensioner. Potential damage couldn't really say, might be nothing at all but could have easily knocked a few things on it way out depending on where it went.
Tensioner is held on with a couple of bolts into the side of the head, air box needs to be removed to allow access.
What part is gone, or might be easier to answer whats left ?
im sure there was a post before that somebody had put up about there tensioner pulley that had melted into a lump after the bearings seized...ill see if i can find it.
