chrishill
Superflex poly bush group buy feeler
Thanks for the welcome,
Think this is the biggest forum i have come across so far.
Never knew there were so many C's out there.
How do you move the smiley things over,
i'm very new to the world of the PC.
PM chrishill, he'll tell you best!
If you mean the window tat pops up, you can drag the edges of the box to make it bigger or hit the square at the top right to maximise the window, does this help?
Chris
updated the first post with prices for the rear bushes, yet to confirm that they are the same across all models, but it looks likely.
no problem BigEastsideTartanTimmyG60, the plan is to leave this thread running til friday to generate interest then post a thread for orders.
if i had any pictures I would chris! I'll see if alec can provide any.
Can i ask whether these bushes are the same as the Mk2 ones?
I am needing some asap really (MOT failure as std ones are knackered)!!!
Thanks
If you want some Chris, just get on to Alec direct. He is busy in his day job. I only ever get his voice mail when I ring.
Gavin
I already have Powerflex puple thing on my VR but Chrishill got some, just needs them fitting now, thanks for the point though
Chris
Basically yes please to these........
I need a full set for both front wishbones after finding one of mine was a passat one today! I'll buy 2 vag WB's without the bushes and nail a set of these pupies. Also my rear bump stop are apparantly "MISSING"!!
A. Can i get this lot
B. Is this a feeler, where do i sign up!?
pm Chrishill as he was in contact with the supplier and should be agle to point you in the right direction with names and numbers of sort it out for you, either way you'll get them sorted!
You'r car's going to be spot on with all these new bushes, mounts and stuff, what else you got planned?
Chris
