mrbeige 0 Posted April 18, 2005 I want to have a go at this myself, so how do I go about smothing the line that runs along the top edge of the bumpers? Just filler and a lot of sanding? If I want to relocate the front reg plate, to smooth out the recess, do I use fibre glass then filler, or just filler? Not done anything like this, and thought I should give it a whirl, as both bumpers need spraying anyway (scuffs and stone chips!) Any advice is much appreciated.... :) Quote Share this post Link to post Share on other sites
VR6 0 Posted April 18, 2005 Personally, and not that I know very much at all about custom bodywork, I'd avoid using filler where possible. Surely any little knock to the bumper would cause it to crack? Plastic welding? Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted April 18, 2005 plastic welding is what you should be doing... use as little filler as poss Quote Share this post Link to post Share on other sites
mrbeige 0 Posted April 18, 2005 plastic welding is what you should be doing... use as little filler as poss Is plastic welding the sort of thing you can do yourself? And if so, what do I need to do it? Obviously a plastic welder but where do I get one and how much are they? Anything else I'd need? The line along the top of the bumper, can that just be sanded out? Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted April 18, 2005 yep, use a large soldering iron, cut some plastic out from another old bumper so its the same material. Use the soldering iron to get the piece of plastic you want to weld into place and do the best you can then cut up some strips of plastic and feed them into the joins with the soldering iron, then sand down and jobs a good'un! Its not too hard mate, I did my rear bumper towing eye, see my gallery for out come! Good luck.. not sure about the line at the top of the bumper, prob have to fill it a bit..? Quote Share this post Link to post Share on other sites
bcstudent 0 Posted April 18, 2005 That has GOT to stink! You may want to attempt that method of plastic welding in a well ventilated area..... Quote Share this post Link to post Share on other sites
flusted 0 Posted April 19, 2005 I glued an old number plate in my recess then filled over it! it has cracked tho Quote Share this post Link to post Share on other sites
rradodth 0 Posted April 21, 2005 ive smoothed out my fogs, left my numberplate where it is, i think it looks awesome! just need to get it sprayed now!! Quote Share this post Link to post Share on other sites
mrbeige 0 Posted April 21, 2005 ive smoothed out my fogs, left my numberplate where it is, i think it looks awesome! just need to get it sprayed now!! Any pics?? I did think about that, as well as smoothing all of it and putting and indicator in the headlight, but wasn't sure of the MOT implications? Quote Share this post Link to post Share on other sites
flusted 0 Posted April 22, 2005 I had mine completly smooth! put the indicator in the spotlight.No probs with mot Quote Share this post Link to post Share on other sites
Phil K 0 Posted April 22, 2005 I think the bumper needs to have at least the indicators in it other wise it ends up looking a bit "special"! losing the fogs and smooting the plate recess looks good though - the green feature C that was up for sale recently looked great like that 8) Quote Share this post Link to post Share on other sites
Majik 0 Posted April 22, 2005 I quite liked the look of the flushed bumper when i first saw it in pvw (capnahabs car), but it reminds me of the smooth tailgate mod on the mk2 where it lost its appeal later on. Quote Share this post Link to post Share on other sites
flusted 0 Posted April 22, 2005 I got slated for my all smooth bumper! Quote Share this post Link to post Share on other sites
