Dixxy 0 Posted April 18, 2005 Just upgraded my brakes to 312mm Audi TT brakes... good improvment. I've taken step by step pictures etc and have loads of information about what you'll need for the upgrade, i'll get all this posted soon. (PLEASE LET ME KNOW IF THIS HAS BEEN DONE ALREADY NO POINT IN DOING IT TWICE) Wanted to know if there is a bigger master servo to fit the VR6, if so give me the info. Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted April 19, 2005 Well, what spacers you used to get them to line up is always useful. Quote Share this post Link to post Share on other sites
Dixxy 0 Posted April 19, 2005 I found you need spot on 6mm spacers. And 6mm longer bolts to hold the carriers on. Got the bolts from the running gear of a TT. Brought some 2mm deep washers to space with as couldn't seem to get any custom spacers made up. Not to difficult all in all... i would advise get the parts together before you start though. Quote Share this post Link to post Share on other sites
Dixxy 0 Posted April 19, 2005 Any idea of a bigger brake servo that would fit? Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted April 19, 2005 Sorry - no. The bolts for the carriers are same for the Corrado and the TT so which ones are you using? Hi-tensile 7mm spacers are available from AMD for ~£30. Quote Share this post Link to post Share on other sites
Dixxy 0 Posted April 19, 2005 Using bolts from inside of the rear suspension arm on a TT, these are a bit longer but same thread and strength. Picked these up from a Knowledgeable VW scrapper along with the brakes. 7mm for my money wasn't dead centre but i stand to be corrected. Thanks for the AMD tip. At this stage tho, not sure if i can be bothered to take it all off again. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted April 19, 2005 I am about to do the 312mm 4motion brakes on mine and it looks like I will only need a 4mm spacer (2x2mm washers) in there. Thats using 4motion calipers, carriers and discs on VR6 hub carriers. Jay Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted April 20, 2005 Dixxy said: Just upgraded my brakes to 312mm Audi TT brakes... good improvment. I've taken step by step pictures etc and have loads of information about what you'll need for the upgrade, i'll get all this posted soon. (PLEASE LET ME KNOW IF THIS HAS BEEN DONE ALREADY NO POINT IN DOING IT TWICE) Wanted to know if there is a bigger master servo to fit the VR6, if so give me the info. You can submit this to the 'Wheels and Brakes' section of the Knowledge Base here: http://the-corrado.net/.archive/forum/kb.php?mode=add&cat=8 You will need to use IMG tags to put images in. If you need any web hosting for these, let me or one of the mods know - we sort it out for you. Quote Share this post Link to post Share on other sites
OSV 0 Posted April 20, 2005 What wheel fitment issues are there with the 312mm brakes. ie size and designs? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 20, 2005 They'll go behind the BBS as Asim has them on his car. They are the 288 calipers on bigger discs and as they're already on my car, I checked to see if the 312 discs would go and I think they will, with the 25mm adapters. Unlikely with the 20mm. Quote Share this post Link to post Share on other sites
OSV 0 Posted April 20, 2005 Sounds promising, Thanks Kev. Speedlines of course will be a altogether different matter Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 20, 2005 Yeah the 288 discs/calipers only just fit behind the Speedlines (more room behind solitudes though), so 312s won't fit unfortunately! Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted April 20, 2005 16" wheels wheels from an A3 or TT fit over 312mm brakes just fine though. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted April 25, 2005 Dixxy said: Any idea of a bigger brake servo that would fit? You can use the larger ones from a later model mk3, but you wouls have to change out the whole thing...not just the servo. I have the 312mm setup also. They barely fit behind my old 16in Oettinger Type E's Quote Share this post Link to post Share on other sites
gibber 0 Posted April 25, 2005 Oettinger SLC dont think the bigger servo will fit on a RHD car, the one on my RHD corrado is smaller than my LHD corrado one (which is for sale if anyone want to try and fit it!) and the one on my LHD golf is huge, about 12inch across! Quote Share this post Link to post Share on other sites
RS VR6 0 Posted April 25, 2005 I don't know about the UK...but here in the states, the 97 and up VR6's had the larger setup. You can swap it, but you'll have to swap everything...not just the servo. A large task...not worth it for me. Quote Share this post Link to post Share on other sites
