randal 0 Posted April 26, 2005 I've seen a lot of cars with polished inlet manifolds, alternators, rocker covers etc.. and they look pretty sweet. Now, how exactly do people get that finish? Is it a case of uber-elbow grease sanding, polishing with power drill and bit, buffing etc...? I've never known for sure, wanted to check as I'd like to do the same to mine when I take the head off for work. Is there a specfic procedure, or recommendations? Ta in advance randal Quote Share this post Link to post Share on other sites
golfg60 0 Posted April 26, 2005 I did mine on my golf G60, it came up ok but not quite a show standard. I used as wire wool to start with, which took a long time. You can buy attachments to go into a drill. I then used an electical contact cleaning block then finally a shed load of polish and more hard work. Sorry if thats not much help as its pretyy much what you said anyway... Tom Quote Share this post Link to post Share on other sites
randal 0 Posted April 26, 2005 Damn, so it is a case of mucho elbow grease :D Thanks for the response. Quote Share this post Link to post Share on other sites
coolrado 0 Posted April 26, 2005 get yourself a cheap bench mounted buffer and some buffing wax bars it will make the job so much easier and you should be able to get a mirror finish Quote Share this post Link to post Share on other sites
randal 0 Posted April 26, 2005 hmm, that's not a bad idea. You mean the ones that have a buffing/polishing bad on either side, normally with a guard? Quote Share this post Link to post Share on other sites
coolrado 0 Posted April 26, 2005 yep usually a coarse and fine pad i just bought a conversion kit for my bench grinder from machine mart which comes with a coarse and fine 8" pad and coarse and fine polishing wax Quote Share this post Link to post Share on other sites
randal 0 Posted April 26, 2005 uh oh, methinks a purchase is gonna happen... ...or at the very least a hire! how much did that lot set you back roughly? Quote Share this post Link to post Share on other sites
coolrado 0 Posted April 26, 2005 £9.99 for the bench grinder about 4 years ago in a sale in B&Q and £14 for the buffing kit from machine mart or if you have a decent drill http://www.machinemart.co.uk/product.as ... 2109&g=115 or for a grinder http://www.machinemart.co.uk/ranges.asp?g=106&r=2040 Quote Share this post Link to post Share on other sites
randal 0 Posted April 26, 2005 blimey, that's pretty cheap. thanks for looking those up, much obliged. randal Quote Share this post Link to post Share on other sites
coolrado 0 Posted April 26, 2005 just gotta be carefull when buffing as things do tend to start flying across the garage if they snag on the buffing wheel and definately wear goggles as the wax hurts when you get it in your eyes Quote Share this post Link to post Share on other sites
randal 0 Posted April 26, 2005 Think I'm going to go for the drill option, so goggles and a clear work area are going to be a must! Wax in the eyes - ouch. Sounds like the voice of experience there dude, mucho suckage! :( Quote Share this post Link to post Share on other sites
coolrado 0 Posted April 26, 2005 yep i didnt notice it at first, the wax comes off the wheel in a fine mist when it heats up and starts to sting after a while if it gets in your eyes Quote Share this post Link to post Share on other sites
mrbeige 0 Posted April 26, 2005 I did my manifold with just elbow grease.....should have bought a bench grinder....and a bench......and a shed.....and a garden.... :roll: :lol: Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 26, 2005 I'll go along with the above. Cheapo DIY bench grinders with buffing wheels are ok for smaller jobs but do get very hot after continued use. I buff stainless parts to a mirror finish but have access to a humungus polishing machine/wheels. http://the-corrado.net/.archive/forum/viewtopic.php?t=23132 Quote Share this post Link to post Share on other sites
JBOB 0 Posted April 26, 2005 So what do you use for all the hard to reach bits ??? Quote Share this post Link to post Share on other sites
woody 0 Posted April 27, 2005 Yep i was just wondering that JBOB Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 27, 2005 So what do you use for all the hard to reach bits ??? Polishing spindle mounted in a drill or similar with small buffing wheels. Quote Share this post Link to post Share on other sites
fla 9 Posted April 27, 2005 randal_24, are you doing the manifold etc in situ or removed from the block? Will you also do the alternator etc (i guess you could get a fair finish on that by removing the airbox and using the drill? Quote Share this post Link to post Share on other sites
randal 0 Posted April 27, 2005 I'll be removing the lot when the head comes off, so I figured that's a good a time as any. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted April 27, 2005 http://www.stillie.gixxer.com/index.html step by step instructions on here Quote Share this post Link to post Share on other sites
randal 0 Posted April 27, 2005 Score another point for GIXXERUK :D Nice one! Quote Share this post Link to post Share on other sites
Dixxy 0 Posted April 28, 2005 Have you thought of powder coating? i reckon it looks smarter than polished parts... prob cheaper too. Quote Share this post Link to post Share on other sites
fla 9 Posted April 29, 2005 yeah but can you do this at home? Quote Share this post Link to post Share on other sites
