chris g 0 Posted May 8, 2005 I have a 2.0 16v on a '93 K. Should the windows close when I lock the car or is it an extra or am i talking out my arse? Thanks Chris Quote Share this post Link to post Share on other sites
VR6 0 Posted May 8, 2005 When you turn the key to lock the car, hold it in that position (to the right I think). The windows and sunroof should then close. NB the windows (if both are open) will close one after the other. Quote Share this post Link to post Share on other sites
chris g 0 Posted May 8, 2005 Doesn't seem to work, any ideas why? Quote Share this post Link to post Share on other sites
blackcat 0 Posted May 8, 2005 I have a 1.8 16v on a j plate and I have this window closing feature. When you turn the key to lock the car make sure you hold it in that position. On mine I turn it anti clockwise. Quote Share this post Link to post Share on other sites
randal 0 Posted May 8, 2005 Also depends on the alarm you've got. VR6 has covered the factory way I think, but the after market alarms will almost certainly do things differently. Plus, it depends if your alarm has that feature, eg the Toad alarms are modular and need the total closure module to be added. Quote Share this post Link to post Share on other sites
yalan 0 Posted May 8, 2005 Also depends on the alarm you've got. nah - actually it was a factory standard function - All the later cars will do windows and sunroof from the drivers lock - whether an alarm is fitted or not! Quote Share this post Link to post Share on other sites
randal 0 Posted May 8, 2005 well shut my mouth, I was under hte impression that the total closure function was on the alarm not the car. coo, good to know. Quote Share this post Link to post Share on other sites
VR6 0 Posted May 8, 2005 Yeah it should be on the car. The alarm just utilises this feature, so checking it via the key is the best way to determine if the car does it. Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 8, 2005 Should also work from passenger side. Quote Share this post Link to post Share on other sites
Henny 0 Posted May 9, 2005 if it only works from one sides lock, the odds are that the handle's been replaced with one that's not got the switches built into it (cheap copy) or hasn't had the wiring connected up again inside the door... Quote Share this post Link to post Share on other sites
Phil K 0 Posted May 9, 2005 Seeing as some of the early 2.0 16V C's had late body / early interior would this mean that they may not have the closing sunroof feature? I'd imagine that some of the late G60 owners could answer this seeing as they have the same late / early mix... (mine does windows and s/roof) My alarm uses the factory closure feature by extending the 'lock' pulse for long enough to mimic the key being held in the lock position 8) Quote Share this post Link to post Share on other sites
Guest Posted May 12, 2005 kinda off subject, but not... has anyone de-locked there car and de-pinned car aswell and the been clever enough to wire up a switch to lock/unlock the doors using the existing loom some how? Quote Share this post Link to post Share on other sites
RACK 0 Posted May 12, 2005 My G60 does the windows but not the sunroof. Quote Share this post Link to post Share on other sites
chaz g60 0 Posted May 22, 2005 mine dosent do the sunroof either. Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 22, 2005 kinda off subject, but not... has anyone de-locked there car and de-pinned car aswell and the been clever enough to wire up a switch to lock/unlock the doors using the existing loom some how? Need a rocker switch to feed a +ve pulse onto the control lines for the locking. Have a look at the side of the fusebox where the wires come out of the door. You'll pobably see where the alarm is hooked up to the locking system. Gavin Quote Share this post Link to post Share on other sites
kongo127 0 Posted May 22, 2005 mine dosent do the sunroof either. Neither does mine... :wink: Quote Share this post Link to post Share on other sites
