andy
Black and white tubing!
Whilst fitting my new BMC CDA I removed my carbon canister and was having a bit of a clean up in that area and found some tubing running inside the inner wing (still in the engine bay) its about 5mm bore, black with a white stripe, it disappeared down between the o/s headlight and the radiator. Anyone know what it is for? Its not one of the carbon canister pipes btw!
Outside temp sensor wiring?
Yeah it could be that, if the cable is run in sleeving. Cheers for answers, I'll have a further look!
I haven't got headlight washers and it's not carbon canister tubing, looks like sleeving of some sort I suppose.
