WONGA 0 Posted May 18, 2005 I tried tinting my headlights today,I did 1 and then tried to get the other light off but the rear screw wouldnt budge as its rusted and the screwdriver was just going around and around!!! What can I do to remove the screw? HELP!!!! Quote Share this post Link to post Share on other sites
Phil K 0 Posted May 18, 2005 Do you mean the one down inside the slam panel? Riley had the same problem with his I think and managed to get it free by gently wiggling (technical term) it lose... if it's your nr side one then remove the battery and see if you can get it free with WD40 and a mole wrench (or similar tough bast**d)... Good luck Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 18, 2005 If it's one on the top, grip the head with mole grips, unscrew and pull at the same time. Also try inserting a flat head screw driver under the head, lever upwards whilst unscrewing. If it's the one deep down, try to gain access from behind the headlight. Quote Share this post Link to post Share on other sites
VR6 0 Posted May 18, 2005 Dremmel a groove into it if it's accessible? Think it's a fairly chunky bolt from memory... Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 18, 2005 oops, just read it again. I thought the screw was turning but not coming out. Quote Share this post Link to post Share on other sites
