TomB 0 Posted May 23, 2005 I was poking about in the scappy over the weekend, and saw a set of gauges in a high end (2.4?) Audi (mid-90s saloon), that seemed like the right sort of dimensions for a 'rado. I forgot to take a photo, but there were 3 gauges in the console, one for oil pressure (in bars), one for oil temperature and a third. They'll be of no interest to me, but if anyone else thinks they might be of use, then I can investigate further next time I'm down there. Cheers, Tom Quote Share this post Link to post Share on other sites
Jim 2 Posted May 23, 2005 Sounds like the kind of setup that Henny had... not sure on that though? Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 23, 2005 Tom I have watched several sets go for nearly £50 on ebay. Might be worth getting them anyway if they are cheap enough. Don't forget the pressure sender on the filter mount 17mm and if the oil temp reads to 170 degrees you should get the temp sender too 13mm. Will have a green and black wire on it I sold some on ebay in 2 hours for 35 delivered, clearly too cheap :roll: Don't offer any advice on fitting them like I did, never ending emails from a non-electrician. double :roll: :roll: Gavin Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 23, 2005 some for example VDO gauges Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 23, 2005 (duplicate thread deleted) Quote Share this post Link to post Share on other sites
andycowuk 0 Posted May 23, 2005 from an audi coupe, slight bit of trimmage required. Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 23, 2005 Nice fit Andy. :) Quote Share this post Link to post Share on other sites
Henny 0 Posted May 23, 2005 the Audi 80 ones are angled towards the driver too... 8) Basically the same idea as Andy's got but with the gauges set in at an angle rather than flush... :) Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 23, 2005 andycowuk, thats looks class ...off to ebay (again!) Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 24, 2005 andycowuk, thats looks class ...off to ebay (again!) Have a word with Tomb..... Quote Share this post Link to post Share on other sites
TomB 0 Posted May 24, 2005 Cheers for that, I'll head to the scrappy at the weekend if I get the chance to take some photos/remove them.benji16v, let me know if you're interested. Cheers, Tom Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 24, 2005 TomB, cheers mate, but dont keep `em for me if you do get `em cos i`ve got a few other (finacial) things going on at the minute. sure you could make a couple of quid on ebay though. thanks ben Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 24, 2005 Cheers for that, I'll head to the scrappy at the weekend if I get the chance to take some photos/remove them.benji16v, let me know if you're interested. Cheers, Tom Tom, get as much of the wiring as possible off the gauges. There are a couple of plugs under the centre console. Disconnect there rather than cut the wiring loom. Gavin Quote Share this post Link to post Share on other sites
TomB 0 Posted May 24, 2005 Will do Gavin, cheers for the advice, I think I'll be printing this page out and taking it with me... :-) Quote Share this post Link to post Share on other sites
Cougar 0 Posted May 25, 2005 Looks nice, too bad the breakers here know what they have $$$ Quote Share this post Link to post Share on other sites
