TomB
Oil Gauges from an Audi.
I was poking about in the scappy over the weekend, and saw a set of gauges in a high end (2.4?) Audi (mid-90s saloon), that seemed like the right sort of dimensions for a 'rado. I forgot to take a photo, but there were 3 gauges in the console, one for oil pressure (in bars), one for oil temperature and a third.
They'll be of no interest to me, but if anyone else thinks they might be of use, then I can investigate further next time I'm down there.
Cheers,
Tom
Sounds like the kind of setup that Henny had... not sure on that though?
Tom I have watched several sets go for nearly £50 on ebay. Might be worth getting them anyway if they are cheap enough. Don't forget the pressure sender on the filter mount 17mm and if the oil temp reads to 170 degrees you should get the temp sender too 13mm. Will have a green and black wire on it
I sold some on ebay in 2 hours for 35 delivered, clearly too cheap :roll:
Don't offer any advice on fitting them like I did, never ending emails from a non-electrician. double :roll: :roll:
Gavin
the Audi 80 ones are angled towards the driver too... 8) Basically the same idea as Andy's got but with the gauges set in at an angle rather than flush... :)
Cheers for that, I'll head to the scrappy at the weekend if I get the chance to take some photos/remove them.benji16v, let me know if you're interested.
Cheers,
Tom
TomB,
cheers mate, but dont keep `em for me if you do get `em cos i`ve got a few other (finacial) things going on at the minute.
sure you could make a couple of quid on ebay though.
thanks
ben
Cheers,
Tom
Tom, get as much of the wiring as possible off the gauges. There are a couple of plugs under the centre console. Disconnect there rather than cut the wiring loom.
Gavin
Will do Gavin, cheers for the advice, I think I'll be printing this page out and taking it with me... :-)
