Rossco 0 Posted July 10, 2003 right my box self destructed so i got a new one(cheers struan) and im gonna replace the clutch while im there is there anythin else you guys rekon i should change??? cheers Ross Quote Share this post Link to post Share on other sites
Rams 0 Posted July 10, 2003 There is a tensioner near the gearbox are that is well worth changing whilst the hgearbox is off. Replace the gearbox mount too if its hasnt already been done. Give it a good clean up too, never hurts 8) Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted July 14, 2003 might be worth changing rear mains oil seal (this is a cranksharft oil seal behind clutch pressure plate. iwould change if i had my box out. also the gearbox inputsharft seal _slider bush as if any of these leak it will wreek a new clutch Quote Share this post Link to post Share on other sites
